Cursed Reality
- May 18, 2013
Just got a Cosmos 2, looking to fill it with some fans, would just like to see some different point of views / recommendations.
Case:
Rear: 1x 140mm Exhaust
Top: 3x 120mm Exhaust
Front: 2x 140mm Intake
Side: 2x 120mm Intake
CPU: Noctua NH-D14
2x 120mm
1x 140mm
So far, I have purchased SP120's for the CPU along with a AF140, and 5x AF120, and 3x AF140 for the case. (Quiet Edition)
Boxes have not been opened, as I am waiting for a couple more parts, so returning these won't be a problem if it comes to that. I have been reading reviews on these and a lot of people are not happy about CFM/Noise.
So what i'm asking is, do you have any reccomendations for other fans, or should I just keep the Corsair's.
Prefferably, if you could pick from the sellection here, http://www.memoryexpress.com/Category/CoolingFans that would make my life easier, but if it comes to the better product, newegg.ca or ncix.com can be an option.
Not really on a budget, more or less looking for the most optimal noise/cfm ratio.
So far, alternatives that I looked into are the Spectre Pro's, and Enermax T.B Silence.
Also, a little info on what's in the case, there are 2x 780s, and soon to be a 4770k next week.
Thanks.
Case:
CPU: Noctua NH-D14
2x 120mm
1x 140mm
Thanks.
