- Oct 30, 2004
- Madison, WI
Hey guys its been a really long time since I really looked at home air moves around my case and getting the best CPU cooling I can, so I could use some advice.
Heres what I have for my system:
i5 4590 @3.3ghz (stock for now) - Just bought a Cooler master Hyper 212 EVO for this
8GB corsair vengence DDR3
MSI GTX 960
EVGA 142-HR-E977 Z97 motherboard
I've been playing around with the airflow going around the system, but nothing I do seems to make much of any difference. With the stock cooler I was getting about 30C idle and about 65C load. With the new cooler it really doesn't look that much different - the best I've seen under load is about 60-63C. I am using the TIM that came with the cooler, and thinking that a better TIM would probably help, but I'm not sure it would be that big a difference. I also thought that maybe I used too much paste the first time I applied it, but I took it off and re-applied it with less, tempertures were the same afterwards. I did also used to have both top case fans exhausting and I thought I would try fipping the front around to bring cool air directly to the CPU cooler. It didn't seem to make much of a difference. I'm also including a picture to give you an idea. Any sugestions on optimizing this setup? Best thoughts on the type of TIM to apply?
BTW I cannot turn the cooler 90 degrees so that the fan points up because it hits the RAM when I do that.
MSI GTX 960
