- Jul 31, 2012
- Phoenix Arizona
Hey guys, so i have a TA970 Motherboard, it's quite new, and i have a FX6200 cpu, at 3.8ghz(stock) and im using the stock heatsync as its rather good and my aftermarket one is being used already.
So my issue here is, all of a sudden the cpu fan hasn't gone over 5300 RPM, usually when my temps are 48++ it will kick up to 5700+ to cool it down, Thus making my temps all the time in the 40s. (Yes its loud and i dont mind it)
my cpu fan hasnt been adjusting the past 2 days and i realized it after i noticed my fan was quiet. it wont go above i think 5000 rpm? i'v messed with the auto fan in the bios (old style, motherboard came with a newer bios though) and no luck in the bios. the RPM stays rly low for this fan and i tried using speedfan, i can't push the fan above 4200 RPM. and i'v tried it with auto fan on in bios, and off.. Any ideas or tips?
Prime 95, all 6 cores, 63C, 4300 RPM. remember, this isn't a aftermarket, but if this going its normal speeds it wouldnt be above 52C.
