- Mar 24, 2008
Hello all,
This place is usually my last resort after searching long and hard to find fixes for a problem. You guys are always so helpful.
So I have an Asus laptop, with a first generation core i7 in it. I had a few hardware issues with it during it's warranty, and never really thought it was worth it to send it in (The touchpad is too sensitive, and I have to open a program called "throttlestop" for turbo boosting to work).
Well now, about a month after it's 1 year warranty expired (Murphy's law), I started getting CPU spikes. This is VERY annoying. They are random, no rhyme or reason to it. I will be playing a game, and all of a sudden everything starts skipping, the sound starts glitching, and then everything back to normal for about 15 seconds, and it does it again.
Before anybody suggests it, I have EVERYTHING in msconfig disabled other than microsoft services.
I have a couple theories about what's causing it. For example, I have noticed that at the same time I started to have CPU issues, I also started to have Wi-Fi issues. In my hours of google searching I came upon this link
http://www.techspot.com/community/topics/system-cpu-spikes-from-20-to-50-every-second.168036/
In it, he describes a similar problem, and he says that it was his ethernet card. After looking in my device manager, I have the EXACT same model ethernet card he does. So I tried disabling it. Still didn't fix it. I tried uninstalling it, and it still didn't fix it. But I still believe that the CPU issue is connected somehow to the networking issue, because they both **** out at the same time.
Another thing, reseting ALWAYS fixes it, at least temporarily. If the CPU keeps acting up, or I need internet, I can always reset the computer. Sometimes it will go hours after a reset without a CPU spike, other times it will last 5 minutes before everything starts going haywire again. I can't find any rhyme or reason.
Does anybody have any idea what could be causing this? Or extra steps I can to permanently remove the ethernet card? (I don't need it. I've probably used it once.) Any ideas are apreciated.
