- Dec 1, 2008
- Last 30 Years NE OH
What is the best temp program for fx cpu's.I always trusted CPUID HWMonitor, and use my bios to report cpu core temps.I think its really reporting mobo CPU socket temp.On idle I know most temp programs report false readings, but on load, these programs are very accurate.Now I'm really questioning my real core temp. CPUID HWMonitor and AMD overdrive report my max load temp on my FX 6300 as 58C.I then used core temp(after getting rid of spyware crap) and my max temp on all cores @ 100% did not exceed 42C.I have my overclock at 4.4g on 1.35v.No problems with games or heat.My real problem is what software is accurate.
Something I found that was interesting...
The temps on AMD CPUs are a problem because none of the current programs report the proper temps - according to AMD engineering.
People also confuse the CPU core temp with the CPU socket temp. Many programs report the mobo CPU socket temp which is of no significance since AMD and Intel began using internal CPU temp sensors. Thus you should just ignore the "CPUTIN", "CPU" and BIOS CPU or similar temps as the CPU socket temps can run 10C-25C higher than the CPU core temp depending on the CPU load and socket cooling. The CPU core temp is all that you care about. This is the temp that the temp-cut in uses at TjMax.
There are conflicting reports on the TjMax for the FX-6300 but this temp is of no concern as you should not be operating your CPU at this temp. TjMax is NOT the 24/7 operating temp for the CPU. AFAIK the max 24/7 temp for the FX-6300 is 70C. For the 8-core FX processors it's 61C. So all you care about is that your FX-6300 doesn't exceed 70C under max load, which it should not with proper cooling.
