Hi all,
Got an overheating problem so over to the gurus here.
I was trying to convert a movie from MKV to AVI using Freemake video converter when an alarm sounded from the tower. I closed the program, installed HWMON, started conversion again and checked temps.
The TMPIN2 sensor went to 80 degrees and the alarm sounded again so closed down. I thought maybe thermal paste but I've never seated or re-seated a CPU so went to Dr Google. Read up a bit and pulled out the CPU and heatsink, cleaned both with isopropyl alcohol and used the 2 line method to re-seat it. Ran it for a couple of hours and all seemed OK so tried another movie conversion.......Grrrrr, watched HWMON temps raise slowly until the alarm went off again. This time it did last a bit longer before sounding. Temp graph attached.
System specs
Motherboard:
Gigabyte: Model H97-D3H Intel H97 S1150
CPU: Intel Haswell. Core i7-4790 3.6 GHz 8mb LGA 1150
GPU: Gainward Nvidia GTX760 2Gb PCI-E VGA
RAM: G.Skill Sniper 16Gb (8gbx2) DDR3 1600
SSD: Samsung 840 PRO series. 256Gb SATA 3
HDD: Western Digital 3.5” Black 1Tb SATA 3 7200rpm
PSU: Antec HCG-620w High Current Gamer
Case: Thermaltake A41 USB3 Mid Tower
System specs
Motherboard:
