Hello, I have an Acer RS780HVF Motherboard, Chipset AMD 780G.
My PC is an OEM PC.
currently I have a "AMD Phenom(tm) 9150e Quad-Core Processor 1.80GHz
A ATI Radeon HD 5750 GPU (This was an Upgrade from the onboard ATI HD 3200 gpu) and 4GB RAM.
And this is any files/manuals that you might need to check:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=348
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM3201/AspireM3201nv.shtml
I've updated my BIOS to the latest here is a CPU-Z picture
http://gyazo.com/d95de570a945108162046989c51898b3.png
And my current CPU is AM2+ and I believe AM3 cpus support AM2+ right?
http://gyazo.com/9278fd9f4f2736e799ba3a184966972e
So I researched and asked around and was told that the AMD Phenom II 960T X4 would work. So I got it today and on start up it said
CPU Mismatch Detected!
So I put my old CPU back in.
So I wanted to know if the AMD Phenom II X4 850 Would work
http://www.byhunt.co.uk/tech/index.php?route=product/product&product_id=32059
Example where 850/960T was suggested to work:
http://www.tomshardware.co.uk/forum/318281-10-rs780hvf-combatible-phenom
So do you think the 850 will definitely work? And should the 960T have worked :S?
Thanks for your time.
Edit: In this forum post he used the Phenom II for that motherboard and on the motherboard specs it dsays AMD Phenom[tm] and doesn't say Anything like AMD Phenom II.
http://www.overclockers.com/forums/showthread.php?t=591256
This is exactly said for my motherboard too.
"Processor1 AMD LIVE!™:
AMD Phenom™ X4 quad-core processor
AMD Phenom™ X3 triple-core processor
AMD Athlon™ X2 dual-core processor
AMD Athlon™ processor
AMD Sempron™ processor"
My PC is an OEM PC.
