- Apr 14, 2011
this is the second time the asrock extreme4 z77 has a loose 8x port. and instead of sending it back the 3rd time, i think ill go ahead and just purchase an MSI board listed here
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645
i bought the Asrock Extreme4 z77 last year, but i dont know if its warranty is already expired...ill check that latter because right now the 8x slot is working fine (im the guy that runs crossfire btw)
basically what happens is that after a while my games crash. i tested the primary 8x slot and it works fine. but if i try the second slot it dosent.
it seems like i have to...push the graphics card up in order to get it working just fine.
suggestions? opinions?
EDIT: i heard some whining that i think was coming fromt eh power supply. so i put the pc on its side and found the air intake being blocked by dust. i use an air can (while using a tooth pick to keep the fan from spinning) to blow out the dust. put it back on its side, installed both cards, re-setup crossfire, and i was able to play natural selection 2 just fine without freezing up.
