- May 9, 2012
Hello,
I have planned purchasing the following equipment for a ESXi/High spec machine build. Will I need any other cabling with this configuration? Will I need any further tubing to be able to watercool two Graphics cards, Motherboard and a CPU? Also will the SLI Bridge that comes with the Motherboard be compatiable with a Two way SLI configuration?
UPS - Will the UPS Need to be a higher voltage as i will be running a 1250W power supply and also may be running a router on the UPS also?
What would be the best configuration for the watercooling? Will I need two loops or one loop? Will I need any additional fans with the case? Does anyone have any Guides or posts that can assist with cable management? I want to make this machine as perfect as possible.
Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £649.99 (£779.99)
OCZ Vertex 4 512GB 2.5" SATA-3 Solid State Hard Drive (VTX4-25SAT3-512G) £466.66(£559.99)
OcUK Tech Lab H2O GTX 680 2048MB GDDR5 Nickel Acetal [N680GTX-PM2D2GD5] £441.65 (£529.98) £883.30 (£1,059.96)
OcUK Tech Lab - Asus Rampage IV Extreme Intel X79 Watercooled with EK Full Cover Waterblocks £399.99 (£479.99)
G.Skill TridentX 32GB (4x8GB) DDR3 PC3-19200C10 2400MHz Quad Channel Kit (F3-2400C10Q-32GTX) £299.99(£359.99) £599.98 (£719.98)
OcUK Tech Lab - V12 Watercooled Case - Coolermaster HAF X £262.50(£315.00)
Western Digital VelociRaptor 1TB 10000RPM SATA 6Gb/s 64MB Cache - OEM (WD1000DHTZ) £216.66 (£259.99) £433.32(£519.98)
OCZ ZX Series 1250W '80 Plus Gold' Modular Power Supply £137.49(£164.99)
APC Back-UPS ES 700VA 230V UPS (BE700G-UK) £67.49(£80.99)
LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (Retail) £66.65(£79.98) )
Lamptron FC Touch Fan Controller - Black £41.66(£49.99)
OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black £4.16(£4.99)
OcUK Professional Cat6 RJ45 5m Network Cable - Grey (B6-505) £3.32(£3.98)
EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel £2.29(£2.75) £9.16(£11.00)
OcUK Value SATA-II 45cm Red Data Cable (NLRB-302LOCK) £2.16(£2.59) £6.48(£7.77)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-393-IN - CPU
http://www.overclockers.co.uk/showproduct.php?prodid=HD-109-OC&groupid=701&catid=2104&subcat= - GPU x 2
http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-AS -Watercooled Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MY-083-GS - RAM x2
http://www.overclockers.co.uk/showproduct.php?prodid=WC-036-OE - Case
http://www.overclockers.co.uk/showproduct.php?prodid=HD-385-WD - HDD's x 2
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-OC - Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=UP-017-AP - UPS
http://www.overclockers.co.uk/showproduct.php?prodid=CD-107-LG - BluRay Drive
http://www.overclockers.co.uk/showproduct.php?prodid=BB-004-LP - Fan Controller
http://www.overclockers.co.uk/showproduct.php?prodid=HD-002-OP - 2.5" to 3.5" Bay
http://www.overclockers.co.uk/showproduct.php?prodid=CB-002-OE - Ethernet Cable
http://www.overclockers.co.uk/showproduct.php?prodid=WC-123-EK - Watercooling Compression Fittings x 6
http://www.overclockers.co.uk/showproduct.php?prodid=CB-035-OK - SATA Cables x 3
Thanks In advance and please let me know If you have any further queries/suggestions that may help towards the build. If I have anything else that i need to ask I will open a further reply to this post.
Kind regards
Jacob
Kind regards
Jacob
