AngryGoldfish
- Dec 19, 2014
I've been asking around for some advice on building my first custom loop and thought maybe you folks could offer another set of opinions. I have no experience with liquid cooling—but have been reading and watching build logs on YouTube and other forums. I was initially going to construct the loop in stages by incorporating the GPU block later on and adding a second radiator to cool it, but I was advised against this and have decided to wait until later next year when I can afford it all in one go. I'm hoping to pay no more than £450/€550/$600. I'm based in Ireland and would rather shop from a UK stockist or European dealer. My specs for the build are below (some parts have yet to arrive).
Case - Fractal Define R4 Black
Motherboard - ASRock Z87 Extreme4
PSU - Corsair AX760 with custom sleeved cables
Graphics - Gigabyte G1 Gaming 970 (hoping to achieve 1550Mhz 24/7 @ around 50°C)
CPU - i5-4670K (hoping to achieve 4.5Ghz at around 1.3v & 75-78°C under OCCT)
HDD - WB 3TB Black (storage & games), WD 3TB Green (backup)
SSD - Samsung EVO 840 (boot & programs), Crucial MX100 512GB (games)
The colour scheme will be black with white accents (fans, memory modules, sleeved cables) and subtle red accents (PSU, sleeved cables)
I will probably be using clear coolant as I like the look of it and don't want the tubing to be the main visual focus. I am also hoping for a more subdued and subtle build. I know white and black are starkly contrasting colours, but they also blend together well and don't have to be gaudy like yellow and black or red and white would be. However any advice otherwise or ideas will be greatly appreciated.
The build that has inspired me to go with this project is one I found while Googling Define R4 water cooled builds. I found a build log for it and can copy much of the layout and specifications, but I don't want to copy it without understanding it first, and maybe making a few alterations to best fit my budget, components and aesthetics. This is where I'm hoping you folks can help.
Some components I have been looking at are below:
EK Water Blocks EK-Supremacy EVO - Acetal x 1 (best looking and not too expensive)
EK Water Blocks EK-FC970 GTX WF3 - Acetal+Nickel x1 (only one currently available)
Alphacool NexXxoS ST35 x 2 (for low FPI and thinness)
Swiftech Helix 120 PWM x 6 (for white fan blades, high static pressure and decent dB range)
I will need, from my count, ten fittings. Four for the two radiators, two for the CPU block, two for the GPU and two for the pump/res. I won't be cooling the memory or motherboard chipset. I am thinking of either using the XT45 as there should be enough space in the front for it, or I might even be able to fit a ST30 in push/pull (hence the six Helix fans instead of four). Which would provide the best performance-to-noise ratio? As far as tubing, the build above uses PrimoChill Advanced LRT 3/8 x 1/2 Clear tubing, which I like the look of, and EK-CSQ Nickel Compression Fitting x 4, which I also like the look of.However, on EK's website there appears to be no right-angled fittings available, which I am going to need a couple of [Edit: Found them]. I'm trying to do this build on a budget, with aesthetics, performance and silence being given equal importance, so maybe Bitspower fittings will be too expensive. Any alternatives should I be considering?
Also, can anyone offer an opinion on a pump/reservoir that will fit in the same position as the one in the build above? I was looking at the EK Water Blocks EK-DDC 3.2 pump/res combo, but I have no idea how good it is or whether combos should be considered at all. I don't know how I'm going to be mount it to the floor either.
I'll have more questions to ask in the future, but for now, thanks a lot for any help you can give.
