I'm in the process of writing a .reg file to expedite all my registry tweaks so I don't have to add/change them all one by one on a new install. I'm hoping someone could verify the format for me
so I can be sure I'm writing it correctly. Thanks in advance
Here's what I've written so far...
Are all the values supposed to be added in hex format? If so, is it necessary to enter the value as 000003de or can it be entered as just 3de without all the extra 0's?
Also, some of the keys further down the chain have spaces in the name. Do I have to use an underscore between the words or can it be written the way I have it now?
EDIT: One more question,
RE: String values, is this the correct format "Cache"="REG_SZ:E:\IE Cache" or should there be quotes around the value like this "Cache"="REG_SZ:"E:\IE Cache"" ?
EDIT: Alright, cool beans, I've found most of the syntax online but I'm still on the hunt for an Expandable String Value syntax.
EDIT: I think I found it, please let me know if it's correct.
It's the double back slashes that define an Expandable String Value from a String Value, correct?
Code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem]
"NtfsEncryptPagingFile"="REG_DWORD:1"
"NtfsMemoryUsage"="REG_DWORD:2"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
"HeapDeCommitFreeBlockThreshold"="REG_DWORD:40000"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Update]
"UpdateMode"="REG_DWORD:1"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
"DisablePagingExecutive"="REG_DWORD:1"
"SecondLevelDataCache"="REG_DWORD:400"
"ThirdLevelDataCache"="REG_DWORD:2000"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters]
"EnableSuperfetch"="REG_DWORD:0"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\AFD\Parameters]
"FastCopyReceiveThreshold"="REG_DWORD:5dc"
"FastSendDatagramThreshold"="REG_DWORD:5dc"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters]
"IRPStackSize"="20"
"Size"="REG_DWORD:2"
"SizReqBuf"="REG_DWORD:4000"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"DefaultTTL"="REG_DWORD:80"
Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\wmplayer.exe]
@="%ProgramFiles%\\Windows Media Player\\wmplayer.exe"
"Path"="%ProgramFiles%\\Windows Media Player"
