- Feb 17, 2005
Hey all,
I have another hairbrained topic question.
I was trying to find a way to make a raid 5 array from usb thumb drives. I came across software called virtuaraid from redsky studio, but they went out of business, I think. I cannot get their software anywhere.
I know that software raid is natively supported in windows xp (with a couple of unsupported hacks.):
http://www.tomshardware.com/2004/11/19/using_windowsxp_to_make_raid_5_happen/
But, in order to make a disk dynamic, it has to be non-removable. There is a registry hack for firewire devices to let windows see them as fixed disks:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\dmadmin\Parameters
Then setting the following key: EnableDynamicConversionFor1394
to 1 allows firewire devices to be turned into dynamic disks.
From some other articles I found out that you can take an ide, sata drive, and after hooking them up normally making a dynamic raid array out of them, then after putting them into individual usb enclosures they will still function properly.
Anyway, after reading this (short) article:
http://www.usbhacks.com/forums/viewtopic.php?p=30&sid=e7eb3684dd2236c62bf94f51be1e5bf3
and
http://www.msfn.org/board/index.php?showtopic=69211&st=0
I tried downloading the hitachi fixed disk driver from here:
http://www.xpefiles.com/viewtopic.php?t=92
I used this driver on a 256 mb kingston, and it installed fine (no blue screens, even after reboot), and it works fine; transfers data as it should too.
In the above link there is just the one inf file, and after modifying it appropriately it does appear as a basic disk, (both in diskmgmt.msc, and diskpart.exe) but the option to convert to a dynamic disk is greyed out in diskmgmt.msc, and diskpart.exe gives the following error:
"The selected disk cannot be upgraded to dynamic.
Please select a valid basic disk to convert."
I think what I need to do is somehow include the cfadisk.c file, from the above download, but although I can tell it has something to do with the c (or c++) programming language, I am at a loss as to how to actually include it.
This is the header from the cfadisk.c file (13kb):
* cfadisk.c - CompactFlash fixed disk filter driver
* Copyright (c) Hitachi Global Storage Technologies 2003. All rights reserved.
* This driver filters IOCTL_STORAGE_QUERY_PROPERTY so that Windows XP can
* correctly handle CompactFlash device as a fixed disk.
This is a little beyond me, but I think I am close to being able to do this, anyone have some suggestions?
TIA, Redwraith94
and
TIA, Redwraith94
