- Jul 10, 2010
The loop I'm working on for my desktop is going to have an external rad/pump/res enclosure, however i can't really find any res options that appeal to me. I feel like the cylinder style res has been done to death, so i was hoping to do a DIY solution instead for something a bit more unique. I've come up with a few ideas so far, but I'm not really deadset on any of them.
Does anyone else have experience with this sort of thing? I'd like to hear some creative input and ideas from you guys.
- Glass bottle: I have drilled holes in glass before with diamond dremel bits for other projects, so a led illuminated whiskey or beer bottle could be neat. The main concern i have is the structural integrity. Bottles are generally made to be disposable and not very rugged, and glue/sealant would have to be used, as you can't really tap threads in glass. I would also like to have more than 2 holes tapped for other inlets/outlets, and if you've ever tried to drill glass you know one mistake can ruin the entire project.
- plastic container: Something like this or a bucket would allow for extremely easy system filling and bleeding, but the walls are still too thin to tap, so some sort of glue or sealant would still need to be used to secure the barbs. It's also not very aesthetically pleasing at all...
- custom acrylic res: This would be pretty awesome, as i could design a res that perfectly fits my enclosure, properly tap the threads for barbs, and include a creative design such as a waterfall or cutout pattern. Only issue is i don't believe I have the tools necessary to make cuts straight enough for acrylic welding. I'd imagine tools that would work would be quite pricey as well.
