- Apr 1, 2011
Hi guys,
I've only just purchased Crysis 2 on Steam and already having a major issue. It seems that Crysis 2 is synonymous with graphical issues, so wading through the forums for an answer becomes much more of a problem.
The reason I've joined Overclockers specifically, is because I noticed another user with a similar problem. (RE: http://www.overclockers.com/forums/showthread.php?t=672979)
Crysis has been freezing during single and multi player. Sometimes it freezes, goes black for 5 seconds with the sound continuing in the background and the screen flickers before returning to normal game play. Sometimes it freezes with sound still playing, and I am unable to CTRL+ALT+DEL or ALT+TAB out of it, which forces me to reset my PC.
Tonight I downloaded Catalyst 11.3, as I was using a previous version that came with my new 6970, which I had professionally installed 2 weeks ago.
Now when it freezes, I am able to ALT+TAB to find an error message "The display driver has stopped responding and successfully recovered". Which is, like the poster of the aforementioned thread said; "Really annoying!"
My system specs are as follows;
I<strong></strong>ntel Phenom X4 810 2.6ghz
ATi (I<strong></strong>ntel) Gigabyte 6970 2GB (Overclocked to 950/1440mhz using Catalyst)
6gb 1333hz RAM
Typically my GPU sits around 80 degrees under full load and around 35-39 at idle. I'm really trying to avoid re-installation, as I've downloaded the game from steam, and this would involve having to download it again.
If anyone has had the same problem, and has a solution. Or if you need more information on my problem, or maybe you know a thread already open with this exact issue, please post!
Thanks in advance,
Synthetic87
** EDIT
I restored factory settings on my 6970 Graphics card and so far, so good. I will re-post in a day or two if I find I am still having any major errors. I am, however, still having a minor issue. When I load the game, as the game starts you see the Cryengine Logo (The blue eye). This screen takes literally 25 seconds to load, before moving on. Anyone else get this?
Also, this may prove useful to people with an issue similar to mine. http://forums.overclockers.com.au/showthread.php?t=645774
Why does "I<strong></strong>ntel" get replaced with "A<strong></strong>MD" when it's posted? <- Huh? I actually typed those nouns the other way around :S Strange, but amusing.
6gb 1333hz RAM
Thanks in advance,
Synthetic87
** EDIT
