QuietIce
Disabled
- May 7, 2006
- Anywhere but there
I'm not much on video card performance since most of my games are simulations, which require a lot of video memory but not a lot of speed, so I'm kinda' lost here trying to figure all this out.
I'm curious about the performance of a given video card for CUDA use. I don't use higher-end video cards for games, etc, so this would be a SETI only purchase to push the RAC on some of my older systems. I found a couple of graphs on the message boards showing 9800 and 8800 performance but, to tell the truth, I didn't see a lot of difference in the 9800 cards and half the time the 8800 seemed to be on par with them. From that information I assume video performance (ala 3DMark) isn't a big indicator of SETI performance so I'm trying to figure out what the most cost effective card would be.
I'm also wondering if PCIe (as opposed to PCIe 2.0) will radically effect SETI performance. Given the low CPU use for CUDA I assume the CPU passes off a chuck of data to the GPU, which crunches it then hands it back. If the data exchange between the CPU and GPU is low then the PCIe bandwidth and bus type, except for compatibility issues, may not make a huge difference???
A little insight please?
Thoughts, observations, experiences - anything goes ...!
