The problem is that The Wizard puts out 2100cs/day which would totally unbalance any team he's put on. Also, we don't know that the fourth place team is really in fourth place. It could just be that more of their credit isn't showing up than the other team's. (I was checking out Team B's members on SETI@work and we're missing at least 5000cs). So if we just add the new comers to existing teams it will have to wait until after berkeley fixes the XML and we know the real standings.AQUAJOE said:Lets get it fixed and just ad necomer to the 4th place team. If more then one at a time are being added one to 4th and one to the 3rd and so on.
What do you think?
hallen said:If there is another like "&numlines=" we might be able to capture it in one shot.
QUOTE]
Anyone familiar with PHP5?
I helped myself and wrote a PHP5 script on my server that scans the results and returns the pending credits in this way:
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=0 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=20 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=40 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=60 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=80 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=100 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=120 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=140 ...
Request http://setiweb.ssl.berkeley.edu/results.php?userid=XXXX&offset=160 ...
Done.
AQUAJOE said:Why do we have to restart the race? I don't understand all the other stats pages are getting the same XML and there stuff is right but the race stats are messed up. Just go back and get the info from the XML files since the race started and fix it. Re-adjusting teams isn't fair. Now that people may have picked up more production and those WU's are wasted for race purposes?? Also For Instance my RAC is much higher then it was when race started do I get moved based on that or do you get moved or adjust by original RAC.
I've got a little pit of Perl under my belt as well, and would be willing to help in any way I could. I also know some C++ and Java, but I don't think either would be of much help for capturing the stats.Stryfe said:I'm looking into changing the data source, if anyone knows any programming and has an idea of how to accomplish this I would very much appreciate any tips. (heezer knows ASP and I know Perl, so how to accomplish this in one of those languages would be ideal).
JigPu said:I'm fine with whatever solution is gone with. As it's been said, the XML problems should work themselves out before the race ends, but I'm not against restarting either.
Smarty pants.heezer7 said:Let team D think they are doing good then show them up the moment the xml gets back in order. Think of this as a secret time to get ahead. hehe
Jon
As heezer said we won't be changing the source for the stats. I'm going to play around with different methods of capturing stats and maybe next race we'll make some changes. So I may be PMing you to pick your brain. Or if you've been pondering it and have an amazing idea you just can't wait to share then you PM meJigPu said:I've got a little pit of Perl under my belt as well, and would be willing to help in any way I could. I also know some C++ and Java, but I don't think either would be of much help for capturing the stats.
SCREAMING EAGLE said:Smarty pants.
