- Feb 27, 2012
- Ohio State
- Thread Starter
- #21
Does the PC12800 ram have a separate form factor than say PC17600? Like conceivably could I switch my 1333 MHz ram for like 2200 MHz ram?
from intel cpu white papers, like one here page 49.The retention scheme employed by CEK is designed to support heavy
heatsinks (approximately up to 1000 grams)
pg 85Intel® Xeon® Processor 5300 Series CEK Reference Heatsink Design clip and fasteners assembly have a stiffness of around 160 N/mm [915 lb/in]
Okay, So I'm a little bit confused by the 160N/mm, is this the amount of deflection that the board incurs do to the weight of the heat sink?Nice machining, pretty cool to make your own stuff!
The retention scheme is made to support up to 1000 grams, so clearly ok with that weight. But since you likely will be using your own support mechanism, then the attachment force is really the limitation. The suggested force is 160N/mm.
pg 85
Since using aluminum and copper in direct contact, I understand the need to use dielectic oil, but you will lose some cooling effect. Best oils have thermal conductance of ~ 0.2 W/MK about 1/3 that of water 0.6 W/MK, and spec heat of about 1.6-2 Kj/KgK less than half of water 4.18.
Just out of curiosity, are you using aluminum instead of all copper for weight consideration, or cost, or machining ease?
Also, if you could mill thin straight channels on copper block, and run the water across them with inlet on one side, outlet on other, more similar to internals in top performing blocks, you would get more surface area.
Also, the copper is 15X more expensive than the aluminum in that form factor.Nice machining, pretty cool to make your own stuff!
pg 85
When you say corroded horribly, what do you mean by that? From the inside out? Outiside- in? Both? I was going to apply some sort of clear coating to the exterior surfaces of the cooler.15x..ouch.
The heatsink clamp + weight of the heatsink should apply ~ 160N/mm or 950lbs/inch of force. The sink weight limit of 1000 grams is only because intels heatsink attachment mechanism may not hold more weight than that once motherboard is in vertical position. If building your own attachment for yours, which you will do, then I dont think you need to worry about weight limits for what you are building. As for 160N, just means screw it on tight .
I meant your heatsink is part aluminum and part copper. Swiftech made one long ago with copper bottom and aluminum top, it corroded horribly even with inhibited glycol. But with dielectric, should have less of an issue. And yep, dont have to worry about leaks killing computer. Here, scroll down to aluminum/copper title under corroded rad is pic of swiftech copper base, aluminum top with inhibited coolant.
As for the surface area/internals of block, I just picked this one at random at skinneelabs, happened to be nickel plated, but can see high surface area. Wasnt thinking of that many channels but similar design.
Though will be interesting to see something different, and how it performs.
However, automotive glycol should not be used in a cooling system or heat exchanger because it contains silicate-based rust inhibitors. These inhibitors can gel and foul, coating heat exchanger surfaces and reducing their efficiency.
Okay, I was thinking using an automotive oil filter, that'd be the most economical way I can think of at ~5$ for a filter.Filtration would likely help. Would hinder flow too much in our loops, but if you are using a strong pump...but then flilter would get clogged, so either way will be cleaning maintenance.
Most fittings are nickel plated brass, nickel is supposed to reduce issues with corrosion/oxidation, though may not always work that way. My nickel plated (inside and out) brass fittings are still pristine after 3+ years of use.
Also not everyone gets gunking with antifreeze, the majority dont, I never did. That one person was folding 24/7, ie computer on full load with high temps 24/7, probably increases risk for getting it. But sucks when you do get it.
And for running with just distilled + biocide, here is what a typical all copper block looks like after 1.5yrs. Only affected performance 0.5C, comparing before to after cleaning. I am now running with distilled 98% with 2% concentrated inhibitors, and see if get more or less fouling or oxidation, ie just for experimental value.
Yike's that isn't cheap. I was thinking about using something like this http://www.amazon.com/Volt-Marine-U.../ref=sr_1_182?ie=UTF8&qid=1330829629&sr=8-182pure brass works fine as well. Pumps I and most others use are here.
Ack, No, thats a short use pump, not meant to run for years with no problem.
It's silly huge. I 'm sure it's loud. 7.5 Amps? A huge heat dump problem. NO, please NO.
There is a reason we use very few designs of pumps to WC a PC. Quiet, reliable, small, low wattage heat dump, good flow and pressure charecteristics. And the 35X can be bought for $80 at other places.
Hmph, I haven't actually considered that, I suppose I need to do a bit of research on pumps. I was hoping to get something with a robust stainless steel or cast iron housing.How much heat does a 10W DDC-1 or 18W DDC-2 put into a loop? If you tell me 10W and 18W respectively, I can safely tell you that you should look deeper into power and efficiency.
I'm not disagreeing with you entirely (I'm sure the marine pump has a higher heat dump than an MCP35x), but I'd be surprised if the pump he picked would noticeably raise loop temperatures. It consumes 90W of power, but that doesn't mean it dumps 90W of heat into the loop (and judging by just how much more flow/head it has than the MCP35x, I'm sure the majority of that 90W goes into useful energy, not residual heat).
edit: merz.38: You'll notice you're going to get a bunch of suggestions to use PC-oriented parts and such (for good reason, mind you), instead of other ones. I would take a look at these parts and think about why they were designed the way they were. For instance, the MCP35x is one of the best, if not the best computer-designed pumps. It has plenty of flow and head pressure for almost any WC loop, it's very quiet, and it's extremely compact. It also uses very little power. All things that are a huge plus for PC watercooling. What you'll have to think of is why the parts you may initially think to use would not be beneficial in a computer loop, and then judge which parts to get from there.
Okay, this is good advice.How much heat does a 10W DDC-1 or 18W DDC-2 put into a loop? If you tell me 10W and 18W respectively, I can safely tell you that you should look deeper into power and efficiency.
You'll have to forgive my skepticism about my hardware selection. I haven't dabbled with liquid cooling at all before.
