Sounds like you want to drive image your complete system with all the software on it set just like you like it to be.
Slipstreaming is for Windows OS only.
Drive Imaging software is numerous, best "in the world" is not free and it's this one: http://www.terabyteunlimited.com/
I've been posting on this forum for fifteen years.
I personally tested Drive Imaging programs since the last century, all the brand names ever released.
I found TeraByte to be the best, by far. This is not spam but reliable information based in first hand experience.
Error detected running command: 'C:\Program Files (x86)\Windows Kits\10\Assessment and Deployment Kit\Deployment Tools\AMD64\BCDBoot\bcdedit.exe -store "offline installer\Content\Boot\bcd" /create "{5270009b-2047-4a50-a654-4072cdb68558}" -d "Litetouch Boot [MEDIA001] (x64)" -application OSLOADER' Exit code is: 1
Error text is: The boot configuration data store could not be opened. The system cannot find the file specified.
whats wrong with using the built in windows image backup utility? i've always found that to be pretty easy.
did you run the command above using an administrator command prompt (right click run as administrator?)
That was one of the top fixes that I saw after googling the error message with bcdedit.
