- Jul 17, 2013
So, my GPU block for my 290 came today anf I finally finished building my loop.
Until now I had only a 30mm 480 radiator and cpu + universal gpu block, now I have a full cover gpu block and I added a 30mm 240, a 45mm 240 and a 45mm 420 radiator. I have about 2 Liters of water in my loop.
I had my D5 always on setting 1. Quiet and sufficent, but now I don't know if it's enough. I will do some test and observe it when my pc is up and running. It is still in bleeding and leak testing phase.
My question is: Do you think settings 1 may be still enough for this loop?
I'm not concerned about flow rate, since it has been proven not to be that big of a factor and with this much rad surface I really doubt I get any temp issues.
I'm more thinking about the pump itself and if it suffers on a lower setting.
Usually its the higher the speed the bigger the strain on the pump, but might a too slow turning pump have to work against some sort of a resistance/gravity, thus beeing exposed to an even bigger strain?
I know the D5 is a centrifugal pump and maybe my thinking relates more to a impeller pump, but I still wanted to ask you guys
