- Jul 4, 2004
Hey Everybody!
Couple of quick questions. Workin on first water cooling kit! I was considering either a swiftech\asetek\danger den kit to make things easier (Especially w/ the instructions! Still want to be very careful). I am considering which radiator to use. I have a Kingwin KT436 case that has 2x80mm fans in the back of the case. I can either get 1 or 2 80mm Radiators or I can get a 120mm radiator and mount it outside the case via a swiftech rad-box mounting kit. Is the performace pretty much the same\lower\higher\etc? Also, any places that I can read a step by step walkthrough to see if I can learn more about installs? Would anyone recommend one kit over the other? Im prob starting w/ just cpu and adding NB and GPU later. Thanks!!
-Jason
-Jason
