Danger Den Maze4-1 GPU Tec Block (Black)
Compatibility ATI: Most Radeon Series blocks with the two hole mounted fans. Excludes the All-In-Wonders at this time
Compatibility Nvidia: As far as we can tell there is complete support for 4 series on up (including FX). Holes are available for the 2 and 3 series and should work also.
NOTE: The use of the water block may require the removal of stock RAM sinks. They can be replaced with these TweakMonster RAM Sinks.
Includes -
Includes - 2 Stainless Steel Bolts, Spacers, Nuts, Springs,
Dielectric Grease, Neoprene, Support Plate, 80W Peltier,
MAZE4 GPU Cold Plate, Socket Wrech, and 4 mounting screws.
Can run with or without a peltier (Up to 40mm x 40mm)
im considering getting the above but i know notthing about pelts and whatnot would i need to buy anything extra or could it be added to the system i have below? also round about what temps and oc's would i get on a xfx 6600gt if anyone knows?
thanks in advance
Includes -
thanks in advance
