Here's the parts list, everything is ordered and on-hand, except one DDC pump top.
Danger Den Tower 29 - Black Series LDR case
Option 1: Case color = style blood shot - Dark red front & rear
Option 2: Drive bay = single 5-1/4
Option 3: Front radiator = 560mm 4x140mm size
Option 4: Bottom radiator = 360mm 3x120mm size
Dual brackets for DD-RAD-Reservoir
DD-RAD-Reservoir x 2
Laing DDC-12v 18 Watt Version 3.2 pump x 2
XSPC / Liang DDC Acrylic Replacement Top x 2
Black Ice SR1 560 radiator (4 x 140)
4 x 140mm Yate Loon medium speed (clear/red led)
Black Ice SR1 460 radiator (3 x 120)
3 x 120mm Yate Loon medium speed (black)
EK Supreme HF CPU Waterblock - Nickel / Acrylic
EK Rampage II Extreme waterblock v2
EK GeForce 480 GTX waterblock - Nickel
EK FC Bridge Triple (Serial) - SLI Connection
EK FC Link GeForce x 2
EK FC Link Blank - Serial x 1
Bitspower Matte Black Ultimate G1/4 Thread 1/2" ID x 3/4" OD Rotary Compression Fitting x 12
Bitspower Matte Black G1/4 Thread 90-Degree Rotary 1/2" ID x 3/4" OD Compression Fitting x 6
PrimoChill PrimoFlex PRO LRT Tubing 1/2" ID 3/4" OD with 1/8" Wall - UV Red x 15 feet
Arctic Cooling MX-3 TIM
IandH Silver KillCoils x 2
My existing PC will be transferred to the new case setup. Here are the specs.
Asus Rampage II Extreme
Intel Core i7 920 D0 stepping
Corsair TR3X6G1600C8D 6gb
Intel X25M SSDA2M080G2GC 80gb
Seagate ST31500541AS 1.5TB
EVGA GTX480 Superclock x 2
Dell U2410 Ultrasharp 24" monitors x 3
Plextor PX-806SA optical drive
Corsair AX1200 Power supply
Here's a link to the picture of the system running in my (rather overcrowded) Antec Skeleton .
http://www.acme-labs.net/img/DSC00930.JPG
I do have a question;
What's the best direction for the radiator fans? Given that there is a radiator in the front of the DD case and in the bottom I'm not exactly sure. Right now I have it set to pull air in from the bottom, and push air out of the case in the front.
I've got the case assembled, the radiators and fans installed, the reservoir mount, and one of the pumps installed. Strangely one of the acrylic tops I received from FrozenCPU was previously used and damaged. I would have just polished up the top and called it a day, but the threads were actually stripped as well. Even though I spent ~$1,000 with them they still made me ship it back and would not cross ship the replacement. So right now I'm blaming FrozenCPU for the delay.
A few things I've run into along the way so far;
1. Bitspower 1/2" ID 3/4" OD compression fittings are best described as big by large. You can not fit two of them on the bottom of the Danger Den Rad reservoir.
2. I'm using M4 .7 x 40mm countersunk screws from Ace Hardware (28 of them) to mount the fans/radiators to the case. That came to a whopping $6. They are the perfect length to avoid damaging the radiators when taking into account the thickness of the acrylic panels and the fans.
3. The DDC Liang pumps didn't mount very well with the Danger Den supplied hardware, so I added some M5 washers from Lowes to the mounting points to solidify things. For a kit designed for those pumps, you'd think it would come with better hardware.
I chose the EK blocks because I could brand match between the CPU and GPU blocks, and I liked the EK link setup between cards better than DangerDen or Koolance's options. I originally was just going to get the DangerDen CPU/GPU blocks, but after reading Skinneelabs it became apparent that wasn't a very good idea.
I'm kind of doubting the decision to go with the big 1/2" ID 3/4" OD tubing and Bitspower compression fittings at this point. Perhaps I'll feel differently about them when it's all done, but they are a MAJOR pain in the *** to assemble and route the tubing. Can someone remind me that the 1/2" ID tubing works better so I don't feel so bad?
I know everything is more exciting with pictures, I'm going to take some good ones on the DSLR on Friday. Right now I'm building the tubing setups and getting things ready as much as I can. Given the constraints above about the fittings on the reservoirs I am probably going to have to place another order for more Bitspower 90 degree fittings. I use my computer way too much to take it offline for a week, so hopefully I can time things where I can do most of the installation in ~48 hours or so.
Does anyone see any glaring holes in my setup? All comments (and flames) welcome. More soon.
