- Oct 29, 2005
- Oregon
Apple bought the weather ap Dark Sky and then cut android off on Aug 1st, making it available only on the apple store.
Some guy hacked it and using apple's api ported it back to droid. All the payed features are disabled but still show. No widgets at all nor any notification area stuff either. Opens and works great. Has ability to save 6 different locations you can swipe between. You can choose to not give it your gps location and it happily accepts both US zip codes as well as City names from anywhere in the world from the search box. It wants to run at start but I disabled that on my phone and used Warden to disable some other stuff it doesn't need either like billing, widgets and whatnot.
It's on a public Telegram (ap) channel. Install telegram, open it, and then just do a search for 'darker sky' to get the free apk download link.
https://www.xda-developers.com/dark-sky-android-bring-back/ 19.18mb
I wasn't using any ap at all, only my browser. Hopefully apple doesn't change the api any time soon.
