- Apr 29, 2001
System specs:
Gigabyte GA-P35-DS3L
Intel Q6600 (8x400MHz) 3.2GHz
8GB of RAM (two Corsair TWIN2x2GB 4GB sets, so all banks are filled.)
FSB:RAM ratio is 1:1
4-4-4-12 timings - rock solid
I had to add +.1v to (G)MCH to make it stable here.
Right now, I am testing 4-4-4-10 (2.1v, 800MHz) right now and I hope it's stable because post-login Vista took literally half the time it used to! )
4-4-4-8 WILL hang the system.
The BIOS read 1.945v for the RAM despite setting it in the BIOS to run at 2.1v. (+.3v manually added)
If I did +.4v, might 4-4-4-8 do any good? (Right now it can't get past the POST, and the BIOS paints .4v in pink and not flashing red )
What about 3-3-3-6 (won't even post)
There is one other value, tRFC, which is at 42. Dare I touch this number?
Any help would be most appreciated, thank you for reading!
