- Feb 10, 2010
- America's Finest city "San Diego"
last night I installed the swiftech h20-220 water cooling kit on my cpu. I set up the system, and did a 30min test before I had to go to work. I did not see any leaks before I left or when I came home. I ran the system again for another hour with no leaks. I went to put every thing back in fired up the system, but I forgot to give the video card power. It made a loud beeping sound, so I shut the system down. I did not notice it was not plugged in, and i turned it on more time same beeping sound. I started to take every thing out, and notice that I did not plug it in. I tested the card on another system and it works. I took out my water cooler to see if some how I killed my cpu from that. I had the block on the cpu while doing my testing. After taking every thing out I put the air cooler back in to see if the system would work. When I turned on the system the fan connected to the heatsink was sputtering. I am not sure if the mb is dead or the cpu possiable both.
help plz
help plz
