- Feb 28, 2004
- Claymont Delaware 19703
I am a proud owner of this fantastic monitor. Loving it every time I use it, its absolutely an amazing kit and well worth the cost.
Ok well I just want to give some real evidence of the 60hz vs 75hz frame updating. (I won't really call it refresh cos that just confuses as you can already read from previous posts)
Basically if the lcd monitor is running at 75hz it can "change" its pixels 75 times per second.
You won't notice it very well when v-sync is on because v-sync is a configuration for smoothing out your visuals, so its not really good to have it on if you need to spot small imperfections during updates.
The best way I found out to test 60hz vs 75hz is actually in Photoshop CS4 with gpu acceleration, you will also need to make sure your GUI is NOT v-syncd, Vista Aero for example is v-syncd, XP is the best to use.
Basically just open up a picture and go into Photoshop's fullscreen mode and use the grab tool and just throw the picture around the screen, you will notice the tearing as the picture moves, you should see a difference in the update from the tearing, there will be what seems like more tearing on a 75hz BUT the tearing will be a lot closer together. Where as the tearing on a 60hz update will be a lot wider and not as smooth because of the longer update interval.
Considering most peoples eyes can't really see more than 60 frames per second it won't make much difference to most people.
If you want the real refresh rate of an LCD then its basically what your eyes can handle since its just constantly on!
Or technically if you want to use the milliseconds, a potential 1000/6 = 166.7 frame updates per second. So technically an LCD display can potentially handle up to the equivelant of over 160hz at 6ms.
Damn I'm good kek
http://www.lcdreviewz.com/review_Dell_2209WA
according to this review the colours arent accurate?
I'm using the monitor for matte paintings so I want accurate colours....
is there special software on windows that flips everything when the monitor is turned to its side? If so is it available for osx?
you sure you got everything right as well as the checkbox that says allow modes this monitor does not support?
dont have the latest drivers but i dont see why a different driver would screw with things.
