- Oct 26, 2009
- Argentina, Buenos Aires
No problem , I'm a mod in this site as well if anyone has any doubt about my "legitimacy" as a real user http://www.europeinruins.com/index.php?action=profile
Did all that but it wont freaking update.But let me retry it.Maybe i did smething wrongDevice Manager > Monitors > select the Dell 2209wa > Update Driver Software > Browse my computer for driver software > Let me pick from a list of device drivers on my computer > Have disk > select the .inf file in the zip and install it.
From the dell web site, at Spain
Resolución óptima:
1.680 X 1.050 a 60 Hz
WTF?????
Working well for me. Thanks a bunch! Gotta say I was skeptical, being y our first post and all so I was wary to try it. Thanks a bunch though, works great. BTW, whats your steam name? I will add you for l4d play.
Even though I manually set it to 1680x1050.
I tried this
Horizontal front porch: 48
Active horizontal pixels: 1680
Horizontal total: 1840
Horizontal sync width: 32
Horizontal sync polarity: -
Vertical front porch: 3
Active vertical lines: 1050
Vertical total: 1087
Vertical sync width: 6
Vertical sync polarity: +
Then set the desired refresh rate to 75 Hz.
I have Windows7 RTM 64 bit on my laptop.
Do you guys think that having my laptop setup with dual display could be the problem?
Has anyone else had this issue?
Thanks
all i did in win 7 64 with the latest driver was to select CVT reduced blank under the timing section instead of manual... worked like a charm.
