- Apr 13, 2004
- Joint Base MDL NJ
Long story short, I deploy to Japan in ~6 months and I am looking to migrate out of my current full tower setup into a mATX to help save on shipping costs. I want to use most of what I currently have (in sig) to maximize $$ savings but understand I may have to swap out a part or two in order to make it fit.
I am looking at getting the Thermaltake Core V21 Black Micro ATX cube as my case, as I like the look and want to be able to install the mobo horizontally. My main concern about this is if my Corsair RM750i can fit into it as I just bought it recently and don't want to purchase another. If not, what other mATX cases that are very comparable in ventilation and the same mobo orientation that my PSU could squeeze into?
The mobo I am looking into is the Asus M5A78L-M/ USB3 AMD 760G mATX Motherboard. Again, I would like to use my current CPU, DDR3 and have 8 channel audio for my 7.1 Tiamat headphones, so this board seems to be the logical choice. My only concern with this is if I will be able to turn off the on-board graphics and it not affect my R9 390?
The one draw back to moving to mATX will be that I will not be able to use my Thermaltake Bigwater 760 plus in this case as it requires 2x 5.25 bays. So if someone could give me a decent AIO that would be great. I will not be doing any crazy high OC, just a very mild 24/7 OC on my CPU. I don't want to run on air cooled so that I can keep the noise the rig will make very low. The keys to it are that it will still fit into the case above and be on the cheap side.
Any help on this build or suggests about using other products would be greatly appreciated.
-Seabee
-Seabee
