Hi all,
I really hope to get some help from you guys as you are my last option.
I have a Dfi Nf3 UT250 ultra-d 939 with an opteron 148 running with Patriot XBLK (tccd). All ok!!!
Now i've bought 2 kits 2*512 Adata Vitesta DDR600 real cheap but they won't run. I've tried everything i know. I have the 711 oficial bios from DFI. I put the bios settings to default and using only one kit it won't run. Neither with both kits. I've tried push up voltages to 2.9 with 3-4-4-8, and still the same thing. I've put ratios and nothing.
Is there any compatibility problem with these modules? The board works fine with my patriot modules, so why not with these ones?
I really could use some help.
Greats from Portugal!
