i just came back from a trip and realized that my computer doesn't want to turn on. i don't know if there's been like a lightning storm or something, but the whole system just doesn't turn on.
when i try to turn it on nothing happens - no fans start spinning or any other noise. all quiet. the only thing that indicates any "life" is the yellow light on the motherboard and actually also the green one behind the LAN cable plug
- first i tested the PSU (OCZ 520). i unplugged it from the motherboard and left only a couple of fans attached to it and i connected pins 13 and 14 like explained here. all 3 green lights turned on, and both fans (including the PSU ones) started spinning. didn't see any problems.
should i presume that the PSU is perfectly fine?
- i disassembled the whole system and took the mobo out of the case. cleared the CMOS by shifting the CMOS jumper for 10 seconds. removed everything from it - RAM, video card.. except for the CPU (and its fan), which is still on the mobo - didn't touch it. plugged the PSU cable in the mobo and connected the power pins with a pin, to exclude the case power button from the equation. NOTHING. no life what so ever, except that yellow light on the mobo.
is it gone or is there anything else i can do to test it?
thanks!
thanks!
