As of today, DFI Nforce4 SLI-DR and DFI UT Nforce4 Ultra-D are becoming available in retail stock.
A price-performance PCI-e system (as of Feb 01, 05):
DFI UT Nforce4 Ultra-D $160 or DFI Nforce4 SLI-DR $210
Winchester 3000+ / 3200+ $150 - 200
XP-90 $40
2 x 256 MB or 2 x 512 MB TCCD based memory modules, e.g. G. Skill PC4400 LE, $130 - 260
6600 GT or 6800 GT depends on budget and level of gaming needs $200 - 400
Fortron Blue Storm 500W AX500-A or Antec Neo Power 480W or OCZ PowerStream 520W (try reusing PSU first) $90 - 120
Total = $770 - 1230 (depends on 512/1024 MB of memory and video card)
The Nforce4 Ultra-D can potentially run dual video cards, either in x16/x2 DXG mode or real x8/x8 SLI mode after mod.
Anandtech just put up a review "DFI nForce4: SLI and Ultra for Mad Overclockers"
http://www.anandtech.com/mb/showdoc.aspx?i=2337
Nforce4 chipsets with PCI-e, SLI features
DFI LanParty NForce4
Both the SLI-DR version and the Ultra-D version use the exact same PCB layout.
Both versions have 2 PCI-e x16 slots, 1 PCI-e x4 slot, 1 PCI-e x1 slot.
Both versions have 2 regular PCI slots.
Vcore can be adjusted to 2.1 V, Vdimm to 4 V.
The SLI version has 2 x16 PCI-e slots for dual video cards each running x8 bandwidth.
The Ultra-D version has 2 x16 PCI-e slots for dual video cards running x16 and x2 bandwidth respectively.
In dual video card mode, it has been reported that the Ultra-D DXG mode is about 10% less video performance than the SLI mode, but about $50 less.
The SLI-DR version has 4 SATA + 4 SATA2 channels, whereas the Ultra-D version has 4 SATA2 channels.
For the detailed specification, refer to the following DFI links.
UT Nforce4 Ultra-D
http://www.dfi.com.tw/Product/xx_pr....jsp?PRODUCT_ID=3471&CATEGORY_TYPE=LP&SITE=NA
Dual Xpress Graphics (DXG) mode in DFI UT Nforce4 Ultra-D:
http://www.dfi.com.tw/Press/press_h...&TITLE_ID=4890&LINKED_URL=arch344.jsp&SITE=NA
Nforce4 SLI-DR
http://www.dfi.com.tw/Product/xx_pr....jsp?PRODUCT_ID=3449&CATEGORY_TYPE=LP&SITE=NA
A64 Nforce4 939 Motherboards
XP-90 $40
UT Nforce4 Ultra-D
Nforce4 SLI-DR
