- Jan 10, 2012
- Idaho
I did some searching and haven't seen this mentioned so I figured I'd bring this up...
I've been reading a lot lately how people are trying to cool their systems to sub-ambient or sub-zero without using a pot and LN2 or DICE directly, ie they want a more long term solution. While I don't have an answer, I do have an idea.
When I was active duty military, we would train to dispose of chemical munitions (yep, I disarmed bombs) using a slurry of DICE and alcohol, preferably methanol, but isopropyl alcohol usually sufficed. I know everyone here who has read up on using dry ice for cooling a computer knows about using these ingredients, but I don't know if the advantages of a slurry are known, or how to make it. Simply, a slurry holds a lower temperature for a longer amount of time. As for making it, there are two ways. The hard way: breaking apart the dry ice manually or with a blender (pretty sure that's what's recommended on here) and mix it in. The easy way...though expensive: use a CO2 fire extinguisher. That's also not very useful for benching because to do it requires a lot of solvent. But here's where my idea comes into play.
For liquid cooling systems I've heard about some who put the radiator into an ice bath to get maximum cooling during their runs. So, why not do the same with an alcohol (whatever type you choose to use)/DICE slurry? We would take a five gallon bucket, cover it with several layers of insulation (including the lid) then fill it about 2/3 of the way with the solvent. Cover it with a thick towel and insert the fire extinguisher under the towel then discharge...a lot. lol You'll get a slurry usually around -90 to -75. With the lid on it can last quite some time, depending on the ambient temperature of course. Yes, this can all be done manually with chunks of dry ice chopped or chipped, it just takes longer. Anyway, the thought is, run the insulated tubing through a hole in the lid and have the radiator in the bucket. Use an appropriate coolant in the system (anti-freeze/water mix, cooling system safe alcohol, etc) and you should have quite an effective sub-zero system without the hassle of downtime while setting the system up for a DICE pot. Just keep an eye on solvent/DICE levels and top off if necessary...and make sure it's vented.
Just a thought anyway.
