- Jul 12, 2010
OK so I just bought my 2nd 5770, planning on the crossfire (naturally)
First question: difference between the two cards? Physically I note they have the same cooler but the cards themselves look considerably different: different color (1 brown 1 green) and one is an inch longer than the other. In addition I notice on startup the shorter green one (cant tell them apart now ) - it's LED light flickers a little bit on bootup and is not as bright as the other. Don't think it's a power issue, both are on two sperate rails from a Corsair HX 750W.
Secondly when installing the 2nd card I noted (well it had happened for a while but I didnt give a **** previously) that CCC/AMDCC wont launch. The process kicks on for a second and then vanishes. Tried reinstalling all the C++ Redistributables, Tried Driver Sweeper, And I kept getting errors during the driver install attempts:
At my wits end to the point where I have just decided to just blast it and reformat Windows which I am in the middle of. But of course now Im left here wondering, is there a key difference between the cards, will it affect crossfire?
Also this is my first Crossfire setup and would like to get pointed to some basics - ie. can you switch between Single and Dual card mode on the fly or does it require physical removal when you want to do it?
Thanks.
Edit: ASUS M4A89GTD PRO/USB3 AM3 1055T THUBAN PHENOM II X6 4GB DDR3 1333Mhz PCI-E x16 (2)* {2 cards x8 x8 or 1 card x16}
For 5770X2 is there a wrong way to attach the bridge? Should I use both bridge connectors or does it only use 1?
Code:
Catalyst™ Install Manager
Installation Report
12/01/11 23:25:53
Hardware information
Name AMD Radeon Graphics Processor
Manufacturer Advanced Micro Devices, Inc.
Device ID 0x68b8
Vendor ID 0x1002
Class Code 0x030000
Revision ID 0x00
Subsystem ID 0xd132
Subsystem vendor ID 0x174b
Other hardware
Existing packages
AMD USB Filter Driver
AMD APP SDK Runtime
The Lord of the Rings FREE Trial
HDMI/DP Audio Driver
Microsoft Visual C++ 2010 Redistributable
Communication Opt-in
AMD Drag and Drop Transcoding
AMD Media Foundation Decoders
Packages for install
Application Profiles
Final Status: Success
Version of Item: 2.0.4331.36041
AMD Catalyst Install Manager
Version of Item: 3.0.851.0
AMD Display Driver
Version of Item: 8.911.0.0000
Version of Item: 7.12.0.7702
AMD VISION Engine Control Center
Version of Item: 2011.1025.2231.38573
Other detected devices
Device ID 0x9601
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x9601
Subsystem vendor ID 0x1022
Device ID 0x9603
Vendor ID 0x1022
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
Subsystem vendor ID 0x0000
Device ID 0xaa58
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x00
Subsystem ID 0xaa58
Device ID 0x960b
Vendor ID 0x1022
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x68b8
Vendor ID 0x1002
Class Code 0x030000
Revision ID 0x00
Subsystem ID 0x1482
Device ID 0xaa58
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x00
Subsystem ID 0xaa58
Device ID 0x9604
Vendor ID 0x1022
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x9608
Vendor ID 0x1022
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x9609
Vendor ID 0x1022
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
ATI Integrated SATA Support
Device ID 0x4390
Vendor ID 0x1002
Class Code 0x01018f
Revision ID 0x40
Subsystem ID 0x4390
Subsystem vendor ID 0x1002
ATI Integrated SMBus Support
Device ID 0x4385
Vendor ID 0x1002
Class Code 0x0c0500
Revision ID 0x41
Subsystem ID 0x0000
Device ID 0x439c
Vendor ID 0x1002
Class Code 0x01018a
Revision ID 0x40
Subsystem ID 0x439c
ATI Integrated Azalia Support
Device ID 0x4383
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x40
Subsystem ID 0x8410
Subsystem vendor ID 0x1043
Device ID 0x4384
Vendor ID 0x1002
Class Code 0x060401
Revision ID 0x40
Subsystem ID 0x0000
Device ID 0x43a0
Vendor ID 0x1002
Class Code 0x060400
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x1200
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x1201
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x1202
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x1203
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x0000
Device ID 0x1204
Vendor ID 0x1022
Class Code 0x060000
Revision ID 0x00
Subsystem ID 0x0000
Error messages
Thanks.
