(A Lengthy sidenote: A high leakage chip draws a lot of watts for a given vcore and tends to run hot at said given vcore, a low leakage chip draws less at the same vcore and runs cooler. Generally speaking low leakage chips are nice for air OCing as heat is the primary issue. High leakage chips can generally survive more vcore for longer and hence are the chips of choice for extreme cooling (read: dry ice(-78c) and liquid nitrogen (-196c), really extreme) operations in the benching world. Whether this still holds true in reality for FX bits I don't know, as far as I can tell they all leak rather impressively when the vcore starts going up. At stock vcore less so, they're sort of weird that way)
In any case, they all start off trying to be the same chip. In this case I don't think either of them is really a higher or lower binned chip even, it's just a question of where AMD wants to market them.
Of course, unless I'm totally mistaken (I may well be), the FX4xxx and FX6xxx series are defective FX8xxx silicon in the first place, so calling one FX4xxx a partial defective and the other not is sort of silly I suppose.
Realistically I should have gone to bed an hour ago and am now rambling intensely.
Suffice to say, it doesn't really matter which chip you get unless you're going to run them at stock. If you're OCing (I'd hope so), buy the cheaper one.
