- Mar 13, 2006
Just want to double check that this is NOT a system that you/your friend do not have permissions to change settings on.
Assuming you are supposed to be tinkering:
Open up Control panel go to whichever adapter is active and manually set your DNS to 8.8.8.8 either as primary or as secondary.
Assuming that 192.168.1.1 is the valid DNS server, your system is either never talking to it (which is likely), or not getting a response from it. Try 8.8.8.8 and see if that fixes the issue. If it does, then try it as secondary and see.
Unless you manually add whatever the hostname and/or IP of all INTERNAL systems you need to connect to your Hosts, you may run into the opposite of your current issue. You can access the interwebs fine but local stuff is only by IP.
