- Nov 29, 2011
- Gold Coast, Australia.
hi, this will be my first loop (i used to use closed loops; Khuler H20, Corsair H100)
Koolance EXOS 2.5 (simply because im putting in a mini fridge )
i'll be cooling a GTX 590(adding a second when i start my socket 2011), and my i5 @ 5.1ghz with half inch tubing
(I've modified a bar fridge to mount the EXOS (air temp -1~4c)
EDIT** thinking of modifing a chest freezer (-4~0c) and adding a few extra fans in the freezer to give awesome airflow. **
***i'll be putting the whole EXOS system in the freezer on mounts so it wont touch the sides*** will the frost be a problem? or would there be a solution like sprinkling salt? or silica? ***
my plates are- CPU; Heatkiller 3.0 1155/1156
GPU; Heatkiller GPU-X3 (GTX 590 plate)
with around 16' of 1/2" tubing
so i was wondering, how much coolant will i need and will i need a second pump/res?
