- May 22, 2011
- USA
The loop will eventually bleed out so I don't think that is the issue. I posted that link to show the loss of temp (0.05) while using a angle fitting. Now if you multiply that for the rest of the loop and lets not forget the blocks and the rads, it not as bad as some people think it is because once you're loop is in the 1.0-1.5 GPM constantly, you're good to go because presumably, you're running a single premium pump.
