That looks good, but you have to run P95 a bit more than 3 minutes
Usually, the instruction set in the 10th/15th minute increase the temps by 5/10c.
Run it at least (very least!) 2 hours to check for stability.
Just as an example, I thought the rig in sig was [email protected]/1.28v, but P95 crashed after 3 hours, and it needs 1.31v.
If not stable, it can go through a 1 or 2 hours stress test with no error/BSOD/reboot, and crash after 2 mins in BF4 or Witcher 3. Talking from experience here
For FX on ASUS boards I typically run ultra high on CPU and high on NB. UH keeps the CPU voltage closest to bios settings from my experience.
That was about 30 minutes in to prime
My bad, I thought you were checking the temps when the screenshot were taken...
Still, go for a good 2 hours at least.
LLC on extreme will overshoot the set voltage in BIOS typically. You might end up making it hotter
what setting would you suggest? After 1 hour of prime at 4.635ghz temps peaked at 65c at the socket and 57c at the core but held steady around 61c and 51c average respectively
Weak core perhaps.. Nothing one can do about it.So 2 hours of prime and 5 of the 6 cores completed, core 5 failed 1 hour 17 minutes in due to number of warnings being exceeded. Any suggestions? Thanks in advance.
Sounds good, one last test since you're now blowing the warm air into the case you may want to try the GFX card as well. For me when I test stability of the system and how well I'm exhausting air and keeping everything cool. I will run P95 with unigine heaven running on the gfx card as well. This will produce maximum heat and soon let me know if things are exhausting adequately
