- Nov 12, 2012
I was checking some things when I noticed my mother board only supports
Memory
Number of Memory Slots
2×240pin
Memory Standard
DDR3 1866(O.C.) / 1600(O.C.) / 1333 / 1066
Maximum Memory Supported
8GB
Channel Supported
Dual Channel
And the memory I was getting was 1600, but only available if I OC.
So I looked at new egg and filtered the search and now i am confused again.....
I was thinking there would only be 1333 memory and nothing but it.
But there are three different types of 1333 memory
DDR3 1333 (PC3 10600)
DDR3 1333 (PC3 10660)
DDR3 1333 (PC3 10666)
Now I am confused again and I am not sure which is the correct speed to choose?!?!?!
Here is my motherboard I am buying...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795
thanks!
Memory
2×240pin
Memory Standard
8GB
Channel Supported
Dual Channel
thanks!
