- Feb 16, 2004
back in Feb. I unlocked my 1800+ for the first time. to fill the pits I used nail polish then a conductive pen and covered everything with some clear nail polish, it worked fine on my A7V333.
just over a month ago I got an A7N8X-E Deluxe with the thought of eventually getting a mobile, after getting a water setup and seeing how far I could push this pally. also because I'm not ready for A64 just yet
anyways..
about two weeks ago I tried to see if another burn in session (5x100 @1.8vcore) would help me get a slightly higher OC. but when I was done I had trouble going back to the same settings. I thought that maybe the unlock I did back in feb went bad, since I could only select 11x and 11.5x multipliers.
and isn't this board supposed to automatically unlock unlockable cpus?
so I finally decided to re-do it.
I cleaned the stuff off using non-acetone nail polish remover (all I could find in my house), but it seems as if some of the silver flakes got into the exposed pits and may have grounded the L1, L3 and L4 bridges? at least as far as I can tell based on the diode test on my multimeter and testing various points.
since I don't know the internals of the chip I don't know what I should be measuring/getting here.
could someone please point out the correct places to measure.
also is there something I could use to get rid of the silver without hurting the chip?
in the meantime I'll have to get some acetone based carbuerator cleaner.
if anything I can just try a socket mod to set the multi, but as I'm sure you all know it's not as nice as a fully unlocked cpu.
anyways..
