N
nerdlogic
Guest
arabarabian said:I think that the best method of lapping is to first to a fine sandpaper, 1400. Then finish it off with the finest steel wool you can get.
Thank you,
Daniel
Steel wool??? unless is's a sheet and you're doing it over a flat surface, forget it...I also don't get how steel wool would do any good.
The best method(for us non-professionals) as given by BillA and Graystar:
Sand only in one direction, meaning take the hs and push it in one direction, pick it up, put it back at its starting point, and push again. NEVER rotate the HS and try to apply pressure evenly over every part of the HS.
I believe that anything over 800 or 1000 won't give you much benefit. I also don't see the benefit of polishing either.
