- Dec 7, 2003
Yes. I guess for someone with any basic experience, putting together a relay switch takes like this take about 10 minutes. But if you want, you can just use a paperclip.
The easiest way to convert a 3pin plug to a 4pin molex is buy an adaptor from your local computer store (compusa, frys)--just bring the fan so you make sure you keep the genders of your connectors right.
Male=metal spike
Female=metal receptor
The key is the metal connector NOT the plastic housing!
Most 3pin fans end in a 3pin female. Most powersupplies terminate in a 4pin female. So the adaptor you want will probably have a 4pin male on one end and a 3pin male on the other.
Male=metal spike
