Trust the Burning Issues acticle.
You can just connect the 14 pin to a ground. You can kind of see it in the top picture:
I tried to make is few permanant changes as possible, still, I reversed the fan in the second PSU to
BLOW through the heat sinks, rather than pull through, so it can be positioned the way it is, pushing the inside air out through the PSU out the front of the box. If I didn't have to cut cables or leads, I didn't.
I also cut a notch out next to the original PSU and placed a female plug cobbled from an old PSU, then soldered on a cord so that I could maintain a normal-ish plug on the back for the second PSU inside.
I really should sleeve everything, but the drives are plenty cool with the Stealth 120 blowing over them and the CPU seems chipper enough for now, so I'm not bending over backwards to get to it.
(And no, while the pictures show it sitting on carpet, I didn't do any of the inside work on that stuff. To much risk of static!)
