Hi!
I currently have a custom loop with a 1080 Ti and two 980 TI's. They are connected with a EKWB Triple Terminal.
I plan to purchase a 3090 and ditch the two 980 Ti's (but keep the 1080 Ti). I am a little bit worried about the space needed for the 3090. Theoretically I would use a Dual terminal for this but I am not sure they would be able to be mounted that close to one another. Specifically the end of the card (where u connect your HDMI/DVI etc) is massive on the 3090 and would probably sit in the way of the 1080Ti mounted below.
Anybody have any pointers?
Thank u very much!
Thank u very much!
