hacktic said:16* = 160,.....165,166,167.......my RAM is crucial PC2100 256mb x1
hacktic said:yep doing 120 now....well that's the max i can go? i'm fine with it.... thanks a lot...
hacktic said:oh alright!. but then u guys started commenting about this and that....it went off topic
batboy said:Ok, I looked up the manual and I now have an good idea what settings you might try after you check to see what your load CPU temps are (report back here when you're done). If temps look good, we'll try a couple of things. I think you're stuck right now because the PCI bus is running too high and is out of spec. At 120 FSB the PCI bus is at 40 MHz using the default 1/3 divider (that's to high to be stable). Fortunately, that Gigabybe mobo has a way to manually change the PCI bus dividers. Get the cooling taken care of and we'll get that bad boy running up to at least 2.4 gig, I promise.
NP thats what all of us are here for. I got alot of help from this forum, and im trying to return the favor. about the sound. my onboard sound worked, but not to well. Playing UT it would get distorted. I just used my audigy. If ur sound doesnt do well when OCing, u may want to invest in a better SC.hacktic said:all the help is so much appreciated esp. NO1
i'll use the search engine in future. btw, i've set my sys down back to 100FSB, cos there seems to be a prob with the onboard sound. no more O/C til maybe i get a new RAM
got beer?
got beer?
yes learn alittle more, but really 133fsb with the 1.8a isnt to much to ask for. u dont even need a volt mod. The stock HSF can probably do it.deez said:
why not just begin with a mild overclock that wont throw your PCI bus way off until you get proper cooling components. If you get it up to 133 then your PCI devices will be back in spec. But till then you can always try around 110FSB and see if your sound still messes up. Onboard sound is generally pretty crappy anyway. You dont have to try to push it to the max on your first try...learn a little bit about all of your components first.
yes it is. maxvla has his stock hsf for the 1.6a at 145fsb. no problem... 133fsb should be obtainable for the 1.6a-1.8a easy. now the 2.0a and above alittle harder.deez said:
I'm sure there are some exceptions. But I dont doubt 133 FSB is easy to hit b/c I've been building a lot of 1.6A systems for work lately and the heatsink barely gets warm. But I've never overclocked one b/c they are not mine.
