TinMan said:To run a dedicated 64bit application you need a 64bit chip.
However to run 32bit software you need a 32bit chip or a 64bit chip that can handle the 32bit code (the Hammer) Intels big boy chip cant do 32bit code (or not well at all), I always forget its name.
There is then crossbred software that have the code in both types 32 and 64 so that duing the install it will detect what it is and use the correct code base on it. (This I assume will be the common one when it gets going)
Thanks for the information.
Wil 64-bit bring a whole new level to gaming?
