- Jul 7, 2010
- Thread Starter
- #21
There are two different settings in power options: "Plugged In" and "On Battery." Check AMD Fusion control center if you've got it. Also check windows advanced power options, "show settings that are not currently visible." I guarantee you it's there somewhere under "Plugged In." "Maximum CPU State: 50%" Or "Max CPU Clock: 800MHz"
I believe I don't have an Amd fusion control center, allthough I do have the standard catylyst control center. I have tried to find the setting which acts up with no luck. Here's a picture of both the Catalyst controll center and the power options.
