Asus Rampage MB e8400
Your Score:
13421 3DMarks
3DMark06
Date:
May 13, 2008 08:08 CDT
Project ID:
6694023
Analyze
Delete
Hardware details
General information
Operating system Microsoft Windows XP
System type 32-bit
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model Rampage Formula
Hard drive model 2 RAPTOR DRIVES SATA 0
Memory 3328 MB
Slot 1 2048 MB
Slot 2 Empty
Slot 3 2048 MB
Slot 4 Empty
Processor information
Processor Intel Core 2 Duo E8400
Processor clock 3555 MHz
Physical / logical processors 1 / 2
Multicore 2 Processor Cores
FSB 397 MHz
Display information
Graphics card NVIDIA GeForce 8800 GTS 512MB
Graphics card vendor Nvidia Corp
Graphics memory 512.0
Core clock 0.0
Memory clock 0.0
Driver name NVIDIA GeForce 8800 GTS 512
Driver version 6.14.11.6921
Driver status WHQL - FM Approved
Linked display adapters No
Result details
Benchmark settings
Program Version 3DMark06 Revision 1 Build 0
Resolution 1280x1024
Full Screen Anti-Aliasing None
Texture Filtering Optimal
Vertex Shader Profile 3_0
Pixel Shader Profile 3_0
Force Full Precision No
Disable Post-processing No
Force Software Vertex Shaders No
Force Software FP Filtering No
Disable Harware Shadow Mapping No
Colour Mipmaps No
Repeat Count Off
Fixed Framerate Off
Main test results
3DMark Score 13421 3DMarks
SM 2.0 Score 6154
SM 3.0 Score 5880
CPU Score 3333
Test Results
Graphics Tests
1 - Return to Proxycon 50.76 FPS
2 - Firefly Forest 51.8 FPS
CPU Tests
CPU1 - Red Valley 1.05 FPS
CPU2 - Red Valley 1.69 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 56.57 FPS
2 - Deep Freeze (SM 3.0) 61.03 FPS
Just copy and pasted my stats here my question is if i bump my ram up to 1066 which it is 1066 ram my nbridge goes from 1.44v to 1.60v is that ok? should i manually lower it......My volts are set to auto rightnow. I am going by the probe program that comes with asus board....When bump it up to 1066 on ram and 400fsb i get red on nb,dram settings it is set to say red at 10percent more than ideal.....Just trying to see if these voltages are ok? all other volts are really low except for the north bridge.
Thanks for your help.
Jay
Your Score:
13421 3DMarks
3DMark06
Date:
Project ID:
6694023
Analyze
Delete
Hardware details
General information
System type 32-bit
Memory 3328 MB
Slot 1 2048 MB
Slot 2 Empty
Slot 3 2048 MB
Slot 4 Empty
FSB 397 MHz
Display information
Core clock 0.0
Memory clock 0.0
Result details
Benchmark settings
Colour Mipmaps No
Repeat Count Off
Fixed Framerate Off
Main test results
SM 2.0 Score 6154
SM 3.0 Score 5880
CPU Score 3333
Test Results
Graphics Tests
CPU Tests
HDR Tests
Jay
