- Oct 11, 2012
- Wisconsin
so I have this eheim water pump.
It is 120V and includes a 12v relay to turn it on with the main system power.
It came with a an inlet of 1/2" or maybe slightly larger and a 3/8" outlet - I have put a 3/8 inlet on it.
Im working on a build and have all the components i need except they wont fit in my current case (no room for even thin rads with fans)
Are these pumps still considered decent? I have found little information on this pump. I believe it is possibly a 1046 but the inlet thread was g1/2" and that makes me think it is an 1100 series. It works well but it is not new - i bought a bunch of watercooling stuff from a pc recycler. I got a ton of random stuff (like a complete koolance Exxos A01 Watercooling kit with cpu (socket 370) and gpu (on a radeon 9800xt) blocks) and this eheim pump.
i began in watercooling in the late 90s and have used pond pumps predominantly but im no longer scavenging parts from junk yards or soldering my own surlyjoe beehive so im trying my best to get up to speed on what is current in the field of water cooling after what must have been close to a 10 year hiatus.
The rest of the system is as follows:
XSPC cpu block
EK 290x waterblock
Alphacool 45mm 2x120mm radiator
Unknown full copper 60mm 1x140mm radiator
3/8 x 5/8 tubing and compression fittings
I have:
FX6100 that runs a 0.05v overvolt for 4.5ghz under an h60 and tops out around 67C
XFX r9 290 reference @stock frequency -3% power profile
8GB Teem Extreme 2400mhz running at 1866 9-9-9-24
gigabyte 990fx-ud3
Seagate 750GB hybrid drive
Samsung 750GB F3 HDD
XSPC cpu block
EK 290x waterblock
I have:
gigabyte 990fx-ud3
