- May 7, 2005
Just got this in my email today. altho its dated the 14th on the website.
https://www.ekwb.com/news/an-apology-from-ek-to-the-enthusiasts/
This may offer a partial explanation for EKWB's recent dismissal of upper management and engineering personnel.
I'm not an ek supporter at all after their nickel plating issue so this doesn't surprise me. It wasn't so much the plating coming off that irritated me it was the response to only buy their overpriced fluid versus fixing the problem that no other company was having that did. At least this time they are taking some responsibility and issuing free upgrades. It will be interesting to see how fast it becomes back ordered to never bee seen again though.
Clearly not enough of a problem that they fixed their testing and build quality as shown by these AMD blocks.To be fair to EK, their warranties are included only when using their fluids, just like every other custom cooling company, since it was tested and there are different combinations of doing ones own fluid, why spend the extra R&D/$$$ and just sell what you know works and doesn't void your warranty? I left DIY fluids to premix and haven't looked back since. Average annual cost is $20 to maintain ones loop. Easy and cheap instead of playing mad scientist with premium custom gear. Not worth the added headaches and cost.
Also, EK I think eventually figured it out later that their thin layer of nickel was being eaten up by silver biocides that folks were using in their DIY fluids. I'm sure it was a big costly headache for them and PR nightmare.
I'm glad you bought into the pre-made fluid gimmick and I know you push it here on the forum but I see no need for it.
I won't take that to offense as I'm pretty intelligent when it comes to these kind of things but I will say this, when you have a $500-$2000 custom liquid cooling system, I think going with what works and having guarantees then cooking up ones own medicine on expensive premium gear, let alone the annual $20 which is a spit in the bucket for a loop worth in that range. If you have a DIY loop from a scrapyard or budgeted, I say have at it.
FYI, I don't get endorsed or paid for anything I say around here. I only wish I did.
I didn't really expect them to replace them because as you said, the warranty wasn't in place when using other fluids. In fact I generally don't consider the warranty when buying pc parts because of what I usually do with them. That being said no other company was having the problem so I would say it was all on them and poor build quality. I'm glad you bought into the pre-made fluid gimmick and I know you push it here on the forum but I see no need for it. To each their own I guess.
